Originally Posted by jzemaxx
Thinking about trying this as a test. I am running now the MMM with a 1515 1Y (2200KV) on 3S 5000mah (10000K total) parallel. I am getting around 23mins with that setup and runs fairly cool. I am thinking about dropping down to the 1515 2Y (1100KV) and going 6S 5000mah. Would I gain anything from this swap? I am thinking I might gain some runtime and drop in heat......it will be geared for the same 36mph. I am trying to get as close to 30mins as possible without a swap, but weight is a major concern. Our races keep getting longer and the pro classes are minimum 30mins and I their is a 45min race coming up later this summer. I would like to keep it down to 1 stop and still have some breathing room.
jzemaxx,
I run the same motor in my MBX5T truggy and with 8S 3200mAh 25C packs (2 4S packs) I constantly get 30 minutes and my packs have over 100 cycles on them. I did a few 45+ minute runs, but I got bored after 30 minutes. My truggy is geared for 36mph (rounded out) without tire ballooning added (as always using BrianG's awesome speed calculator). I still haven't tried my Enerlands and you can go as high as 3700mAh without adding much weight. With the new 30C and 40C packs, I don't see a problem with a efficient HV set up going 45 minutes straight.
