06.10.2009, 05:39 PM
If it's for the motor wire, you could use solid wire if you wanted. Well, actually no because of possible skin-effect (tendency for high frequency signal to travel only on the outside of the wire). Anywho, you could go to a car audio shop and pick up 8-10GA wire pretty cheap for the length you want.
