Finnster
KillaHurtz
Finnster's Avatar
06.10.2009, 11:18 PM
Originally Posted by jzemaxx View Post
I plan to series them to 6S instead of running 2 3S's parallel. I figured a KV of around 1100-1500
I too think your runtime sucks as you are spining the motor too slow, and having to prolly pull a tall gear to get speed. Your runtimes should be quite a bit longer for that much batt.
6S, then use a 1300-1600 kv. I had a 2Y on 8S, and really that's the min you'd want to run. I don't like to run high rpms (~40K+) but its better than running too slow (<25K.) My 2.5D on 5S is quite fast enough and gets good mileage. A 3D on 6S 5000 packs should run quite a long time, more than 23mins for sure.
