06.10.2009, 11:29 PM
OK, I finally made an update:
- Added several brushed motors.
- Fixed LST/LST2 transmission ratios.
- Added LST/LST2 FOC transmission ratio.
- Added Hot Bodies D8 differential ratio.
- Added a note for the old RCM slipperential stating V1 is discontinued.
- Added Mod 1.5 gear pitch.
- Added Losi MRC transmission ratio.
- Removed battery charger data table, selection box, and all code relating to pre-set battery charger information.
- Added new feature to the Power Calculator page. Once the user enters the data into the form and calculates the power figures, it will also provide a table listing estimated pack capacities to get the same runtime at different voltages.
- Removed the Sky & Technologies link (Quark) since the address is no longer active.
- Removed the Beta alert on the BL Parameter Comparison page.
