bustitup
06.11.2009, 01:18 PM
Originally Posted by MetalMan View Post
Awesome! You got lucky If that motor had been available 2 months ago I would have picked it up in a heartbeat... should be PERFECT on 6s. But now I'm running 10s instead so I have no use.
Yes I will putting it in a larger 40" catermaran boat on 10s
maybe even 6s just for sport running
but the thing I found out from steve neu was that the "y" wind motors can be run with a higher timing seting....."D" wind has to be set at the lowest timing ....where Y can be move up = faster
