06.11.2009, 01:41 PM
One go around the block with adapters, charger plugs,differring cell counts and differing taps forced me to look for only one particular adapter. When that failed the second go around the block forced me to get many cheap wires,adapters,boards so that I can do nearly anything I want from now on.
The balance boards really are nice since that eliminates the cell count from the problem and there are only 4 different taps.
Here's what I did in a nutshell:
establish your max cell count.
find charger to match cell count and get adapters to all boards that fits said charger.
Any battery pack up to max cell count can be done on said set-up.
It may not be quite that simple as it sounds, the charger's or balancer's plug and number of pins is a lot of times what is difficult. Identification is half the battle.
