06.12.2009, 05:25 PM
Originally Posted by MetalMan View Post
One flat spot looks a lot cleaner than 2 Though there's nothing wrong with it per se.
Instead of having the shaft turned down to 5mm (maybe I like it thick ) I'm gonna try to set up my XLB with a 9mm wide plastic spur gear, along with a pinion of matching width.
Pinion is gonna cover the other spot.
