06.13.2009, 10:18 PM
You have ALOT of projects going! Hey I'd buy one if it makes production! LOL
I will be welding up the frame soon, looks like I have a line on the motors and should be able to mock the gear boxes up and get an overall size for this beast. This looks to be a very simple setup, worst part will be controlling the blades, the dx6 does not appear to have a knob on it... I could use my M8, but I do not have a mix on that radio for the throttle and steering, and would prefer twin stick control of the drive system. I may just use the 5th channel switch on the radio and vary the endpoint, or try to mix the rate adjustment switch, not even sure if I can do that either. I need to read the manual.
