06.13.2009, 11:34 PM
So you ran the battery to the lvc and when you plugged it in it was at 6v. That is fine. You may want to leave the battery to sit for a few mins after you run it to let the voltage come up a little before you charge it. And if it is warm let it cool before charging.
Just make sure your lvc is set. Sounds like it is a 3v per cell setting.
