01.01.2006, 04:02 PM
Sweet truck! 7 cells would work if you use a receiver pack. Otherwise, you risk the controllers cuting out when the voltage drops(been there, done that). You could also make the 8 cell packs with the two extra cells on a wire and install them on top(6 cells in each holder and the 2 two cell packs on top). With all the work you have into this sweet rig, mounting up a couple extra cells shouldn't be too tough!
