RUSTED
06.15.2009, 12:31 AM
well i finally finished my emaxx and got it running yesterday , after 2 runs with the punch control set to 50% the spider gear got damaged it was the spider gears from a used kyosho mp777 then i changed the spider gears to the ofna titan spider gears and set the punch control to 80% and after 2 runs the spider gears stripped again although im pretty sure everything is meshed correctly.
my LHS sells kyosho inferno diffs and xtm diffs , which is better??
wat diffs r u guys using in ur hybrid bulks??
