nitrostarter
nitrostarter's Avatar
06.15.2009, 11:13 AM
Ah! I see sir. I have my 1521 from boating and they use the 8mm shafts. Thanks for the answer, and you can ignore that email I sent as well.
My follow-up question is do you think there is enough material there to have the 5mm pinions drilled out to 8mm and them still be strong enough?
Thanks Mike!
I may have to get that collet from TDR and bore it to 8mm, and then run you screw on pinions.
N. Rustler conversion
