RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.15.2009, 11:20 AM
2 major problems with drilling the existing pinions:
1) - they are HARD. they would need to be annealed, drilled and re-hardened
2) - they only have 10mm of total material at the set-screw area, which would only leave 1mm wall thickness after boring to 8mm. This is not enough meat.
You probably could make a collar to slide over after boring and make it work, but it will be a bit of work no matter how you slice it.
