Re: wiring 2x controllers in parallel to....??
GriffinRU
Re: wiring 2x controllers in parallel to....?? - 01.02.2006, 01:11 AM
Originally posted by joostin420
i would like to run my 2x lehner 4200's with 2x schulze 18.61k controllers on 12cells.
for example, i know it is possible to run 2x 6cell packs in parallel to run a total of 12cells. is it possible to run both of the controllers sharing 12cells (i.e. running the controllers in parallel)?
thanx,
justin
It would work with no problems in your case and it would be a painful setup for e-maxx type applications.
In your case two motors are not connected to each other directly, so any misbalance would be compensated by wheels not by ESC/Motor/Battery.
In the case when motor tied together (like e-maxx setup through spur gear) any difference in motors RPM (due to the motor mismatch or ESC’s freq/timing mismatch…) will be absorbed by ESC/Motor/Battery. Which translates in ESC failure, Motor overheat or Battery extensive discharge.
Artur
