eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
06.17.2009, 12:15 AM
UPDATE: IT LIVES! It just went out for it's maiden voyage today! we ran it for about 5 minutes or so, then the mass of zipties broke and the chain popped off the sprocket. The setup is as follows:
NeuEnergy 4s 5000mAh 25c sending power to 2 speed controllers, and the headlights. The headlights has 2 switches in parallel. A dashboard switch, and a momentary switch actuated by a servo in 3rd channel. This lets the headlights be turned on remotely or by a manual switch. The speed controllers are a IFI Victor 883 30v brushed controller, powering a 540watt razor scooter motor I found at a garage sale. This motor is in a custom mount welded/fabricated by ben (brushlessboy16) and is driving the solid rear axle by 25 chain. The steering is using the stock drive motor and transmission, powered by a Victor 884 speed controller. The outdrive of the 147:1 transmission has a ton of torque for steering power, and has a piece of allthread on it, for steering. Since I do not have what i need to make it auto centering and limited steering, We just ziptied it to the steering bar, so if me or ben were to oversteer, it would snap the zipties and not break anything else.
for wheels, in the rear we have 13.5"x4" pneumatic wheels from tractor supply, and the fronts have 13.5"x1.5" There is only 1 pic and video of tonight, as we do have finals tomorrow... but stay tuned for more!
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
