06.17.2009, 11:27 AM
Has anyone else had trouble with this particular packs? I'm sure you just got a bad pack, which is bound to happen with lipo's. Again, unless of course it's happened to others, then I will be P!$$#D off.
The way you did the test to figure out the cells resistance is not very accurate however. Was the performance noticeable? How long have you had them? Have you thought about taking the pack apart and doing a high discharge test of each cell?
I am going to try and do a full eagletree run on the pack today if I have time. Yes man, these packs are awesome, but then again I'm sure any high end lipo pack would be killer going from a 7s A123 (2300mah). I might do a high speed run, geared for ~65mph.
Cheers
