06.17.2009, 03:17 PM
So you plan to remove the primary gear reduction unit and just run a pinion and a spur on the center drive? Not sure if it is a center diff, but I have not thoroughly read about this truck yet.
Not sure what reduction is in the diffs, or the tire height. Post up some info and we will see what can be done. Most will say something like a 2215 neu on 10s lipo will be a good starting point.
As far as the gear goes, we need some pics of the center spur to see how it is mounted.
