Matthew_Armeni
Matthew_Armeni's Avatar
06.17.2009, 06:18 PM
Originally Posted by Mentat View Post
honestly even running nitro i never got 1 hour of drive time in on my 8ight-t, nitro problems, waiting for parts to build my race roller up, hop ups, etc... only truggy i have had any time on is my raze st and that was just bashing up and down the street. Ill give it a shot, btw how does the exchange thing work at TEKNO? i want to exchange my 44mm mount for the 42mm. Also didn't you guys say i could exchange the 2shoe clutch for a 3shoe as well? whats the deal on that?
Yes, you can exchange the old style for the new 3 shoe, but it costs $10.00 ($2.00 of that is for S&H). If you were to just buy the 3 shoe it would cost $20.00, so there is a discount for those who upgrade. The exchange for the 44mm mount to the new 42mm is $4.00 for S&H. If you send us both at the same time, include a check/money order (or cash at your own risk) for $12.00 (no reason to double charge on shipping) and we'll send you out the new mount and clutch.
About running the clutch vs. direct drive back to back- radio and ESC settings are usually different. On the direct drive most tend to run higher punch control and also some throttle curve or expo. On the my ESC, I run 20-30% punch and have a linear throttle curve on the ESC and no expo on my radios throttle channel while running the clutch. When I ran direct drive I had between 50-70% punch and around 10-25% expo, depending on the track. If you run the direct drive settings with a clutch it will feel overly mushy at low speeds kind of what like jhautz described. (I'm not implying that this is how jhautz had his setup, I just want people to be aware that the same ESC/radio settings will not yield the best results with either setup.)
  Send a message via AIM to Matthew_Armeni
