06.18.2009, 05:19 AM
yes you make a very good point. I just got thru putting back the Losi electric conversion kit in the package, apparently you can only use their plastic 45t spur gear because its small. i was unable to use my 48t steel spur gear from the stock 8ight-t 1.0 race roller kit because it was a bit larger in diameter. The Losi kit doesnt use the slots in the chassis for the spur gear, they use a plastic mounting surface that sits ontop of the chassis which give their smaller 45t plastic spur gear just enough clearance to run in the center diff mounts. LAME. waste of 79.99. I bought the Tekno for 69.99 with a chassis. i mean come on LOSI what are you trying to pull here. Im going to do a whole write up i think with pics on this issue. crazy.
