Thread: 6s drop off
spcpicard
06.18.2009, 12:24 PM
If you get ~12 minutes of runtime with 3200mAh cells at 6s, that's an average current of 16A, and an average power of 355w. A bit higher power needed than I would expect, but whatever. Anyway, the burst amperage is probably around 100. That would equate to over a 30C rate burst. At those levels, voltage WILL dip and trip your LVC.
Just to clarify, I was getting about 11 mins using 1800 mah of the 3200mah pack. And the hyperion pack is rated 30c cont and 50c burst (according to allerc).
