spcpicard
06.18.2009, 05:18 PM
Originally Posted by stum View Post
I run the Tekno v3 8ight-t (brushless).... this is setup using all the "nitro" parts. I wanted to use the plastic spur with it, I'm sure it would be fine if it would fit :(
Yeah it's a little wider as you've found out, I would just run the steel spur since the only real reason for the plastic is for noise, and you'll find out the tekno clutch sounds really terrible
