SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
06.18.2009, 10:02 PM
I just use double sided foam mounting tape between the motor and the chassis. The chassis will flex naturally, and imo, you don't want the motor to get in the way of that. I also use the same 3mm screws the mount the spur gear to the center diff to mount the motor, and they have worked great.
Area 52 Ranch Raceway
T.R.C.R.
