06.19.2009, 12:46 PM
Originally Posted by Mentat View Post
[/SIZE]EC POWER Hard-case 3000mAh 7.4V LIPO
When you parallel lipos, you double the mah, but the C rating and voltage remains the same. You would have 4s 6000mah 30c in your slash, [/url]
He has a pair of 2s lipos Neil, so if he wanted 4s he could run them in series, for 4s 3000mah 15c. If he ran them in parallel he would have a 2s 6000 15c battery.
That is about half of what that truggy would need to run 4s.
4s setups with truggy size/weight wheels/tires need a good bit of amp capability to operate properly. I would say a 4s lipo capable of at least 150 amps cont would be necessary. So you are looking at a 5000mah 4s 30c lipo.
HC is the best bet for cheap lipos. The zippy line is about the best bet for cheap lipos, at least the specs are correct, unlike most other bargain lipo that are way over rated and puff easily.
