Originally Posted by Wild YFZ 450
Yes it uses a 380 size motor wich is a medusa 28mm series, But in those pics you can see that a Medusa 36-50-???? can fit with some very little modding, Just dremel a bit off the rear shock holder and it will fit, This is what i plan to do when my VXL system dies, This thing is stupid on the 3s 380 I can't imagine 4s 540 can.... I can fit my zippy 3s 1600mah packs in there, There a tight squeeze bit they fit....
I would use two 2s 2200mah packs in a series for the 4s.
