florianz
06.19.2009, 05:20 PM
well I've read the whole thread...
here in germany you can buy a certain carbon which can be bent under heat w/out a problem, as it is a special blend of materials. when it has cooled down, it is like a normal carbon fibre composite.
I don't believe that you can bend finished cfk with heat, whithout having problems in the long run. that's why I have asked.
mr. constructor (his chassis' are even known here in this forum) solved that problem with a patended combination of a aluminium-kickup and cfk carbon chassis.
