mmk - this is a wierd one -lol- Although it doesn't look like it - the wheels are NOT touching anything - it's balancing on the middle of the chassis - just thought it might show a bit of the weight balance maybe? -lol- It's only SLIGHTLY front heavy - not anything NEAR what i was expecting :)
This shows the small alum mount i had made for the ESC to mount to - you can also see just behind it - the hole for the wires to pass through :) The 2 holes in the alum mount are for the zip ties to pass through - it's been secured with some sort of extra strong resin or somethin...
The wires in that shot are as follows....
Bottom left wire (Red/Black/Grey) is for the brake servo...
The next one after that (clockwise - close to motor - also Red/Black/Grey) is for the Forward/Reverse Shift Servo...
Then the BEC wire passes pext to the Shift servo... and the ESC wire is also there on the left.
Dunno why that was relevant - just thought some might be curious i guess -lol-
Hope you like!!!
btw - if you want one of these for yourself - email Rob (Mr Constructor) here :) -
constructor@ace-cars.de
