Originally Posted by Arct1k
PS do the blades overlap otherwise you will have a gap in your cut...
Do the blades spin out to stop the grass filling up under the car?
They are currently set to counter rotate outwards, front and center. I'm with you on that line of thinking.
It should help sweep the grass away and to the side, instead of humping it up underneath.
