Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
06.20.2009, 12:13 PM
I don't think goin from a 33t to a 25t will increase my speed, Im running 3s lipos wich is around 11.1~ volts and I am seeing 52mph tops, Yet the 12 cell Ni-mh setup running a 23t pinion at 14.4volts is seeing 50, And you all know the speed claims by traxxas are a bit off. So i think 33t is not over geared at all as both the ESC and motor reached 130 from about 10 passes, If i was overgeared the temps wouldn't be the same ( ESC- 123, Motor-132) Also the motor had no trouble pulling that gearing either it still did wheelies like crazy, Actually did a 50mph wheelie and it sounded all fine.
  Send a message via AIM to Wild YFZ 450
