01.03.2006, 11:48 AM
the 22 series motors are very big, and would almost definately require a larger motor mount. The 1940 is slightly longer than the 1930, hence it has slightly more torque but a lower kv rating.
I run a lehner BASIC XL2000 on 18cells, and although it is very powerful it tends to run slightly hot. Personally I think that the bk wanderer motors are the best in terms of value for money. Personally, if I was running a 14cells set-up I would go for an wanderer 8XL, or if I had the money a 1940 in the 2400kv range (a 1930 will run hotter than a 1940)
