Semi Pro
Semi Pro's Avatar
06.21.2009, 09:44 PM
This made me laugh, just thought you guys would like to know that.
Just wondering if you can flip the plastic spur over and have it sit closer to the diff cup? I know it has a metal reinforcement plate, does that go between the diff cup and the spur, or outside the spur?
the plate goes on the diff cup first then the gear goes over it, the op may have put it together wrong
its a nice set up because you dont have to open the diff to change the gear, and on a side note they seem to last as long as kyosho nylon gears, as long as you mesh them right they will last years
