4s4p will be the best bet. You won't need much. Here is the tek battery page that does the same thing with an internal BMS
http://www.tekbattery.com/Batteries/PricesDoc.html
4s is the replacement for 12v lead acid. It will get slightly undercharged by a lead acid charger too, which makes it last longer.
