Thread: 6s on M Monster
spcpicard
06.22.2009, 12:02 PM
Originally Posted by johnrobholmes View Post
You would put the servo load on the CC BEC, and I can't comment what is better. I would not use an external BEC personally, as my MMM have been running fine.
ok....of course if you are using the ccbec the load is going to be on it and not the esc??? From my understanding, the ccbec is basically the same thing in the Mmonster except it handles more amps and has adjustable voltage. I guess my question should have just asked if there was any difference between the two as far as one being more efficient or reliable. Also I own 3 MMonster controllers and havent had a problem with any of them, but I also have only previously rand 4 or 5 cells. The 3 locally that I have seen problems with, 2 of them were on 6s and the the third was on 3s. If I can prevent burning up the bec on the MMonster by using the CCbec then why not, expecially if I already have it? Worst case the CCbec fails and I just plug the red wire back in and run the built in bec. Well there could be worst but I'm not going there.
