RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.10.2005, 12:58 AM
Awesome. I can't wait to get the pictures. There are several programming options with that controller. I believe the stock timing for the micro series is set on automatic (controller optimizes timing constantly through the run). I will have to look it up to be sure. If you go for the Gorilla chassis, I recommend the extended version and the motor mount as well. The motor mount will allow you to mount the controller right next to the motor and moves the tranny down and the motor towards the rear, which really helps balance out the truck.
