zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.22.2009, 04:16 PM
....so add some capacitors to the pack, clean the power up IF it were a problem. IMO, you don't need caps.
Redshift, I have 30 55Ah Yellow Tops (AGM spiral wound) waiting to be place in an electric truck conversion. An A123 pack 1/7 the weight has the same punch and power as the best lead acid batt.
A123 starter batts do actually make sense in the long term.
