whitrzac
Can't catch this...
whitrzac's Avatar
06.22.2009, 08:20 PM
I just got the esc back the other day and I need to set the profile to the 7th drive profile...I thought that I had it in that setting, but when Tekin looked at the esc I sent in, it was not in the 7th drive setting. Can some one help me out here.
I did notice a small box on the right side w/reverse next to it...is that the setting to rev. motor direction?
Also, w/regards to lvc.....for a 6s application, do I set it for 3.3...does that mean /cell or should I set it for 19.8 ...I am not sure
you need to check the little box and select the drive profile you want...
set it to 19.8
