brushlessboy16
brushlessboy16's Avatar
06.22.2009, 11:55 PM
I clink mine. by clink i mean hold the pinion gear and wiggle the spur back and forth, there should be about 1/2mm of movement- just enough to make a small clinking noise. if your running a 2200 it will be loud at low rpm and coasting because of the motor design.
