stum
06.23.2009, 06:45 AM
correct it only goes one way, but you need to get it in the cnc part and then (hard to describe) kind of pull it forward a little bit, there is a tiny bit of play. This play seems to be just enough to avoid the rubbing. I pulled the 8e 2.0 apart and there are not any extra spacers/shims etc, its just put together with the o-rings and a single diff shim as shown in the manual. The mount parts are all the normal kit as well. Another guy noted on the other thread that there maybe differences in the actual spur itself? Manufacturing issues?? Now that is pretty interesting, if that is the case, it would cause many of these issues... I don't have extra's to measure, anyone help out here?
