jocktheglide
06.23.2009, 12:38 PM
thank you...I was thinking since the specs on the esc are better on the rx8 would this applicable for the savage flux truck?
I haven't use the motor at all and recently sold to a fellow RCM member. The ESC is so smooth with the motors+gearing I use, that going sensored is pointless in my application. However if I would use the ESC in my 1/10 speed monkey's, than the sensored feature would come in play with the crazy rollouts.
I am very impressed with the RX8 ESC capabilities in my applications. Very easy to program. I did however had to get the Tekin Hotwire to be able to change the timing for the different motors I use.
A friend of mine is also building a Ofna GTP with an RX8, hooked up to a 1515 Tekno neu after seeing my setup in action.
