01.03.2006, 11:38 PM
I will say that if smoke come out then you probably smoke something...
If ESC operational and BEC provides correct voltage (recommend to verify, especialy under load) then probably you just smoke couple (maybe one) FET. Which is Ok and not a big problem, only reduced you current ratings by 10-20A thats it.
Artur
P.S. Sometimes it is possible to create short circuit in windings by pulling magnet to hard through the windings, there are not protected at all...
