06.23.2009, 05:37 PM
It sounds like you are actually running the ESC in reverse when you apply forward throttle. In reverse, the Quark brakes are VERY abrupt. But if you are REALLLLY gentle, you can get proportional brake, but it's still touchy. How do the brakes work when going in reverse? If reverse brakes work normally, then this is the problem.
If this is the case, reset throttle center to 0, and EPA settings to 100%. Make sure servo reversing is set to forward, and recalibrate the radio/ESC.
