Thomas
Thomas's Avatar
06.24.2009, 07:22 PM
Are you guys sure that all A123 2300 mAh cells are the same? I believe that's not the case. The ones with the thin solder tabs probably can't deliver the same current as the ones without solder tabs. I'm buying mine assembled with high-current connections from the European distributor.
