stum
06.25.2009, 06:37 AM
Originally Posted by SpEEdyBL View Post
If you are getting noticeably more runtime at 3.0 volts vs. 3.2 volts, your packs are not good enough. Good lipo packs with properly matched cells will stay strong, suddenly hit the cutoff and be done. At least for my packs, the voltage curve is so steep that there is really no difference in time between 3.0 volts vs. 3.2 volts per cell, so there is no reason to run 3.0 volts when you can run 3.2 volts.
I've never seen a pack that does a full on dump and holds a flat curve going from 14.8v to 12v or (18.5/15 - 22.2/18) and I've seen a lot of eagle tree data. Typical packs even good ones at about 85%-95% of capacity start to drop and the .8 to 1.2v difference means anywhere from 300-900mah (1-3mins) depending on how good the pack is. It maybe only 1min range for a TP, FP, Elite, Neu type pack and closer to the other end w/ some lower quality packs, but it does make a difference.
Lets see your eagle tree or at least some detail about these packs that hold a 14v line until the second they dump... I'm very interested in getting some LOL
