jzemaxx
06.25.2009, 01:47 PM
Originally Posted by Electric Dave View Post
I'm happy with the handling now. I went to stiffer rear springs, heavier oils in the front and rear shocks and 30K in the center. 3 degree toe block from KH. Now it's just getting used to how it handles but I like it...also ditched the stock tires, AKA rules. I bought I-Beams but I tried a friends CityBlocks and liked them much better.
I am running the city's and ibeams as well. I use the ibeams up front and city's in the back for the tracks that are tight where I need a little rotation. Also city in the fronts and ibeams rears work well on loose conditions. The stock tires are great for clay and hot conditions....they seem to bite good there, but other then that, not a big fan.
I'm still running 10K in the center with 7 in front and 2 rear. So far I like that setup. You are probably geared for much higher speed then me so a thicker oil does help that. I will be trying the stiffer purples this weekend. Also found out the ride height was screwed up again. Looks like with time the springs sag a good bit.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
