06.25.2009, 10:15 PM
I appreciate that Bondo! I just want to warn everyone that may be interested in donating test subjects that there is a definite possibility that these tests will destroy the packs under test. At the very least, the packs will have a shorter lifespan.
Even so, it's not nearly done yet as I still need the following:
- MMM ESC (or any ESC that is capable of brushed mode and at least 200A).
- 500,000-1,000,000uF capacitors. Either a bunch of smaller ones paralleled, or one big car audio cap.
- Some type of heatsink. Since I'm using so many resistors, maybe just a 1.8" thick piece of aluminum with a couple fans blowing across them.
- A container and ventilation system if/when the lipos under test decide to vent/flame.
- Assembly involving some pretty heft wire (I have some 8GA and 10GA car audio wire) and a bunch of solder.
