Mentat
Brushless Mentat
Mentat's Avatar
06.26.2009, 02:26 AM
Originally Posted by marzac2 View Post
You CAN use the motor in the larger mount. It is just like the mounting from the Losi diff mount (screws in the front end bell). Only problem is that it won't have the extra support from the rear end.
Just go to the Tekno RC website and look at the product page for the item you want. It should list the information you need for the exchange.
Or you can also contact them by e-mail or phone as well and they will let you know the details.
I would not try to combine any elements of the conversions. This would defeat the purpose of the Tekno chassis. It is drilled and milled to accept the parts it came with. Adding any Losi parts would require you to drill/modify and would add no real benefit. The Losi battery tray sits 10mm higher than the Tekno one (heaviest part is the battery) and you wouldn't want to send your CG up higher. I hope you try the clutch/brake bias, as it is what really sets the two conversions apart. If you are driving on a track, than this will be a big benefit.
Good luck/Good fun!
out of curiosity how do u have your 8T geared?
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
