Originally Posted by Mentat
yeah, i understand all that. i am strickly a 4 cell guy. i purchased the 5 cell to see what it was all about. Thats when i started to experience the heating up. did you read the post? I just used the 5 cell for testing. i wont be using it again, im staying with 4 cell and moving to a 13t pinion.
Whoa ...yes I read the post...and and fortunately there is this thing called a search engine that will tell you about Brushless motor problems
..and it would also answer almost all of the other questions that you created threads for....did you not use the search feature? No starting/turning would be number one....then severe cogging that can't be corrected with gearing change would be two...then excessive heat build up on mild gearing and low voltage setups would be third ...and maybe a grinding sound when you rev the motor and the car spools up like a nitro engine and there is Zero torque....anyone one else correct me if I'm wrong....
