06.27.2009, 02:19 PM
Hey Tim, I have bent plenty of those screws on the upper shock mounts. I planned to drill the mount and top bushing out and use something bigger, like a m4 thread screw. Might be over kill, and then the shock towers may break... Dunno, I will give it a try.
The muggy shocks are identical to the lst shocks save for the shock shafts. So you can buy lst shafts and swap them out and you are good to go. The bodies, pistons, cartridges, etc are all identical.
