Once You Go Black You never go back....
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
Once You Go Black You never go back.... - 06.27.2009, 10:42 PM
Here is my Mini Revo Blacked out, Dyed the chassis and rockers, Then I sprayed the motor mount, Added some black heat shrink here and there, Then I installed a Mamba micro pro, I hated how the stock one had no settings and breaks where horrible, It runs about the same temperature as the stock VXL Around 140 on 3s with 23/50 gearing and the motor runs a bit behind it at 130ish while the lipos (3s 3200mah) Run 80 degrees. I like how I can run the punch control at like 70% and not have to worry about snapping the Driveshafts off the U-joints are going through diffs ( been there done that already)
Name:	Mini E-revo Black Edition.jpg
ID:	7345   Click image for larger version
Name:	Mini E-revo Black Edition V2.jpg
  Send a message via AIM to Wild YFZ 450
