Batfish
Batfish's Avatar
01.04.2006, 11:27 PM
I've made a crude drawing to back up what Mike is saying about reversing the linkage on the servo.
In this drawing the green circular arrows represent the servo movement direction.
You can see that with the servo horn/linkage in position A, the black linkage line is clearly being PULLED away from the blue dot (other end of the linkage).
With the servo horn in position B, the red linkage is clearly PUSHING towards the blue dot.
This shows how you can get the opposite effect by physically moving the servo horn/linkage to the other side of the servo.
Hope this helps!
Image hosted by Photobucket.com
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
