01.04.2006, 11:49 PM
Sounds like you put the diff ring gear together on the wrong side(they must be in opposite side front to rear). No way around it. You have to take apart the bulkless and turn the diff over(put ring gear on other side and re-shim it). The back is easier to swap(no steering to mess with when dis-assembling).
